NPM 11.5 and later prevents an iFrame from displaying within an external web site or a custom web page
Cross-Site Request Forgery (CSRF) and Clickjacking attacks. Cross-Frame X-frame iframe
10/25/2018 2:09 AM
4/28/2021 8:38 PM
The Orion web configuration is changed in NPM 11.5 as a security measure to prevent Cross-Site Request Forgery (CSRF) and Clickjacking attacks.  As a result, displaying resources on Orion in an a custom web page is not possible.
Network Performance Monitor
The following was added to the web config as a security measure.
X-Same-Domain: 1
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
Warnings:
  • Consult your System Administrator before performing the following procedure.
  • The following changes will make the Orion Web Console vulnerable to Cross-Site Request Forgery (CSRF) and Click-jacking attacks.
  • SolarWinds strongly recommends that you only edit the web.cfg file as instructed. Any additional modifications may result in system performance issues or may create an error state.
  • Save a copy of the original web.cfg file to your local drive as a backup file, in case you need to roll back later.
  1. Go to the web folder. By default, it is located at C:\inetpub\SolarWinds.
  2. Open the web.cfg file for editing.
  3. Delete the following key from the file: <add name="X-Frame-Options" value="SAMEORIGIN" />
  4. Click Save.
  5. Press Ctrl+F5 from your web browser.
