NOC View Refresh for NTA
An issue exists with NOC views refreshing too quickly if NTA resources are used in those views. This discusses what can be done about it at this point.
Example: If your NOC view is set to refresh each panel after one minute, and you have seven panels, it should take seven minutes to cycle. If NTA resources are added, the refresh will happen in five minutes if that is the web console setting.
- Remove NTA items from the view.
- Set the web console to refresh the cycle to a longer NOC view.
