Tools
NLST FTP command
The NLST command is used to retrieve a list of files from the server over a previously established data connection. Unlike the LIST command, the server will send only the list of files and no other information on those files. If a parameter is specified, the server returns the list of files contained in the provided path. If no parameter is present, the server uses the client's current working directory.
NLST) FTP command.Product section
Common responses
- 125 FTP response code , 150 FTP response code
- 226 FTP response code , 250 FTP response code
- 421 FTP response code , 425 FTP response code , 426 FTP response code , 450 FTP response code , 451 FTP response code
- 500 FTP response code , 501 FTP response code , 502 FTP response code , 504 FTP response code , 530 FTP response code, 534 FTP response code, 535 FTP response code, 550 FTP response code
