NCM template: Brocade 8510 and 7840 fiber-channel switches (1.3.6.1.4.1.1588.2.1.1)
This article provides a device template to be used with NCM. Depending on the version of NCM you are using, follow the relevant steps to add a template. For instructions, refer to the NCM Administrator Guide.
10/19/2018 8:49 PM
10/19/2018 8:49 PM
Network Configuration Manager
Use the following lines as the actual content of the template:
<!--Copyright 1999-2008 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="Brocade Switches" SystemOID=" 1.3.6.1.4.1.1588.2.1.1">
<Commands>
<Command Name="RESET" Value=""/>
<Command Name="EnterConfigMode" Value="configure"/>
<Command Name="ExitConfigMode" Value="exit"/>
<Command Name="Startup" Value=""/>
<Command Name="Running" Value="configshow"/>
<Command Name="DownloadConfig" Value="configshow"/>
<Command Name="DownloadConfigIndirectSCP" Value="configupload -p scp "${SCPStorageAddress}","${SCPServerUserName}","${StorageFilename}"${CRLF}${SCPServerPassword}"/>
<Command Name="UploadConfigIndirectSCP" Value="configdownload -p scp "${SCPStorageAddress}","${SCPServerUserName}","${StorageFilename}"${CRLF}${SCPServerPassword}"/>
<Command Name="Version" Value="show version"/>
<Command Name="DownloadConfigIndirect" Value="transfer upload mode tftp${CRLF} transfer upload datatype config${CRLF} transfer upload filename ${StorageFilename}${CRLF} transfer upload serverip ${StorageAddress}${CRLF} transfer upload start${CRLF}y"/>
<Command Name="More" Value=" or "/>
</Commands>
</Configuration-Management>
