NCM is not detecting any changes on device configs
At times, although real differences, there are minor changes that are relevant that are detected and flagged. In some situations, differences are altogether ignored and nothing is flagged.
10/19/2018 4:19 PM
10/19/2018 4:19 PM
One of NCMs key features is to detect changes between two configs from the same device and flag for review.
Network Configuration Manager
  1. A comparison criteria was introduced to NCM that makes NCM ignore everything.
  2. NCM_CacheDiffResults table and NCM_ComparisonCache in the NCM database have grown out of sync and is so large the difftool does not work properly.
  1. View custom comparison Criteria and disable them one by one until you see what's causing the issue.
    1. Go to Settings > NCM Settings > Comparison Criteria.
    2. When setting a Criteria to ignore, it is good practice to not only verify the Expression is ignoring the intended line, but also not ignoring anything else.
  2. Use the default Database and Archive Maintenance Job.
    1. Go to My Dashboard > Configs > Jobs.
    2. In the Add Job Specific details for Purge config cache data older than, set a timeframe where you need to run a Config Change report for or select the graphs on the Config Summary page o view.
           Note: storing unneeded data may result in performance issues.
