NCM few nodes failing downloading config files (Connection Refused ) / (Connection TimeOut)/ (Cannot Log into Device : bad password.) Error what should i check?
This article describes how to fix an error "Test Failed Timeout" / when doing a connection test or download config in NCM where you have issue with few devices in NCM
Issue with the NCM job failing for few nodes
You see an error of: "Test Failed Timeout"
- Device configuration
- L2/L3 connectivity
- Device Template
- Incorrect protocol selected in NCM Connection Profile (OR SSH or Telnet is blocked from NCM poller failed to SSH or Telnet to this device )
- Incorrect password in NCM Connection Profile
- Use keyboard interactive authentication YES
- F5s takes a long time to save the UCS file locally
- The file transfer between the device and the TFTP/SCP server takes a long time (Cisco WLC)
- Others
Pick one single node and work along to make sure the node in question actually have no issues with connectivity.
(Please make sure you work on the correct polling Engine where the node is assigned for polling if you have multiple pollers)
Checking NCM Profile
Orion web console > Go to this node "target effected node" > Edit Node > NCM Properties check the Connection Profile "Test" if this successful ?
Checking NCM Profile with SSH Auto
Also please on Orion web console > Go to this node "target effected node" > Edit Node > NCM Properties check the Connection Profile
Select SSHAuto >
Select SSHAuto >
"Test"
In case you are using any connection profile, it is possible connection profile contains old password and you are tyring new password in putty .
Try to type credentials directly for node instead of using profile.
Please double check that these credentials are typed correctly
Please check if you have selected correct protocol for the device in Connection Profile .
For Example : You have selected SSH and device only supported for Telnet .
Double check and make sure correct supported protocol is selected in NCM Connection Profile
Please also try set ‘Use keyboard interactive authentication” option to “Yes” on edit node NCM page and try ones more. Even in case NCM Credential test failed try to downlload the device configuration .
If you have connection failure (Make sure you RDP on the the same Poller where the node is assigned )
Connect with the device using PUTTY and try to list the device configuration
Still failed ?
In this case we have to check the Session Trace for the Node.
Enable Session Trace
- Open the Orion Web Console.
- Go to:Settings > All Settings > Product Specific Settings > CLI Settings
- Enable Session Tracing check box.
- Go to the trace log location:
C:\ProgramData\SolarWinds\Logs\Orion\CLI\Session-Trace\NCM - Delete the trace files.
Now Run the below Test and check the Session Trace log file for the Error (Error will be listed on the bottom of the log file)
Go to the Session Trace File C:\ProgramData\SolarWinds\Logs\Orion\CLI\Session-Trace\NCM
Open this in notepad use the following KB
What is a Session Trace? A Session Trace logs all communication between NCM and the target device, once enabled. This will work only for console communications - where NCM is actively logging into the device to run commands, in order to download, upload or change a configuration. If NCM is manipulating the configuration via SNMP, then you will not see a session trace for that communication.
NCM How to Read a Session Trace
If you are unable to understand the Error why its failing - Open Support Ticket and provide us the Session Trace file.
If you already have case opened please send this Session Trace file through case email
Please do not forget to ZIP the Session Trace file
Open Support Ticket
