NCM device template for Checkpoint Firewall Model 12200 and 15400
Device Template for CheckPoint Firewall
Refer to this article on how to create a Device Template, then use the codes below for the said device.
<Configuration-Management Device="Device Name" SystemOID="Refer to your device's system OID"> <Commands> <Command Name="RESET" Value="set clienv rows 0" /> <Command Name="Reboot" Value="" /> <Command Name="EnterConfigMode" Value="" /> <Command Name="ExitConfigMode" Value="" /> <Command Name="Startup" Value="" /> <Command Name="Running" Value="show configuration" /> <Command Name="DownloadConfig" Value="Show configuration" /> <Command Name="UploadConfig" Value="" /> <Command Name="DownloadConfigIndirect" Value="" /> <Command Name="UploadConfigIndirect" Value="" /> <Command Name="DownloadConfigIndirectSCP" Value="" /> <Command Name="UploadConfigIndirectSCP" Value="" /> <Command Name="EraseConfig" Value="" /> <Command Name="SaveConfig" Value="" /> <Command Name="Version" Value="Show version all" /> <Command Name="Disconnect" Value="" /> <Command Name="configuration" Value="" /> </Commands> </Configuration-Management>
