NCM and Database Connectivity Issues
NCM cannot connect to SQL Server after a crash, reboot, or maintenance.
6/5/2019 9:54 PM
6/5/2019 9:54 PM
SQL becomes unresponsive due to crash, server reboot, maintenance, etc., and NCM is unable to connect to SQL. The following error is noticed:
Service cannot be started. System.Data.SqlClient.SqlException (0x80131904): Login failed for user 'SolarWindsNCMLogon'.
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning()
Network Configuration Manager
Run the NCM configuration wizard selecting all the following options:
  • Database
  • Services
  • Startup Settings
Click through the wizard until you get to the "Database Account" setting and create a new SQL account. Proceed through the configuration wizard and allow it to run. When the configuration wizard is complete, verify that NCM is able to connect to SQL.
