NCM Template - Sierra Wireless (1.3.6.1.4.1.20542)
This article provides a device template to be used with Network Configuration Manager (NCM).
Depending on the version of NCM you are using, follow the relevant steps to add a template. For instructions, refer to the NCM Administrator Guide.
Use following lines as the actual content of the template:
1 <Configuration-Management Device="Sierra Wireless" SystemOID="1.3.6.1.4.1.20542">
2 <Commands>
3 <Command Name="VitualPrompt" Value="OK"/>
4 <Command Name="DownloadConfig" Value="AT&V${CRLF}"/>
5 <Command Name="PreCommand" Value="${CRLF}"/>
6 <Command Name="Version" Value="ATI1"/>
7 </Commands>
8 </Configuration-Management>
