NCM Template - H3C S3100-26TP-EI Ethernet Switches (1.3.6.1.4.1.25506.1.246)
The template to be used in NCM for adding the H3C S3100-26TP-EI Ethernet switches is described.
Depending on your version of NCM, use relevant steps to add template, as described in Creating and Modifying Device Templates in the NCM Administrator Guide .
Use the following template:
01 <Configuration-Management Device="H3C S3100-26TP-EI"SystemOID="1.3.6.1.4.1.25506.1.246">
02 <Commands>
03 <Command Name="ALLOCATEPTY" Value="False" />
04 <Command Name="ENABLEIDENTIFIER" Value=">" />
05 <Command Name="ENABLECOMMAND" Value="super 3" />
06 <Command Name="MENUBASED" Value="False" />
07 <Command Name="RESET" Value="${CRLF}" />
08 <Command Name="REBOOT" Value="reload${CRLF}y${CRLF}y" />
09 <Command Name="EnterConfigMode" Value="system-view" />
10 <Command Name="ExitConfigMode" Value="return" />
11 <Command Name="Startup" Value="saved-configuration" />
12 <Command Name="Running" Value="current-configuration" />
13 <Command Name="EraseConfig" Value="write erase${CRLF}Y" />
14 <Command Name="SaveConfig" Value="save${CRLF}y${CRLF}${CRLF}y${CRLF}" />
15 <Command Name="VERSION" Value="display version" />
16 <Command Name="DownloadConfig" Value="display ${ConfigType}"/>
17 <Command Name="UploadConfig"Value="${EnterConfigMode}${CRLF}${ConfigText}${CRLF}${ExitConfigMode}" />
18 <Command Name="DOWNLOADCONFIGINDIRECT" Value="tftp ${StorageAddress} put config.cfg ${StorageFilename}" />
19 </Commands>
20 </Configuration-Management>
