NCM Device type and model data in SNMP
How to display device model information using SNMP
11/29/2018 10:22 PM
11/29/2018 10:22 PM
You may need to see the device details including the exact model name and IOS versions.
Network Configuration Manager
NA
With Orion the machine type is derived from the Sysobject OID  1.3.6.1.2.1.1.2.0 In some devices like, as an example, the Cisco 3750 devices this would display as 37xx and not 3750 or 3760 etc.
You may need to collect the exact model number of their devices for reporting.
Orion collects the device 'Description using 1.3.6.1.2.1.1.1.0 and this would contain details on the software installed which usually contains the exact model like:-
.1.3.6.1.2.1.1.1.0 = STRING: "Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE10, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 11-Feb-15 11:40 by prod_rel_team"
This can be displayed in a report using the description column.
There are no single OIDs that display specifically the exact model number of the devices.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
