NCM Device Template for Cumulus Switches running Linux
This is a device template you can use for downloading configs for Cumulus Switches
A device template needs to be created for these devices for the configurations to be downloaded in NCM.
<Configuration-Management Device="Cumulus Switch" SystemOID=" 1.3.6.1.4.1">
<Commands>
<Command Name="RESET" Value="" />
<Command Name="Running" Value="running" />
<Command Name="DownloadConfig" Value="net show configuration commands" />
<Command Name="Version" Value="net show version" />
<Command Name="VirtualPrompt" Value="$" />
<Command Name="EnableIdentifier" Value="$" />
<Command Name="UseVirtualPromptForCommands" Value="true" />
<Command Name="Disconnect" Value="exit" />
<Command Name="MenuBased" Value="False" />
<Command Name="Startup" Value="" />
</Commands>
</Configuration-Management>
Save this as a device template and assign it to the Cumulus device.
