NBAR2 configuration
This document will briefly describe the NBAR2 configuration on Cisco devices and some of useful diagnostics commands.
10/19/2018 1:41 AM
6/16/2025 4:05 PM
Netflow Traffic Analyzer
NBAR2 is part of Flexible Netflow (FNF) configuration, to have correctly configured FNF one needs to configure all three parts: recorder, exporter and monitor.
The Following represents the recommended configuration:
1. Recorder:
 flow record SolarwindsNetflow
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect transport tcp flags
 collect interface input
 collect counter bytes long
 collect counter packets long
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
 collect application name
For NBAR2 is crucial the command "collect application name" - this will enable the sending of AppID in each flow.
2. Exporter:
 flow exporter SolarwindsNetflow
 destination 10.140.27.226
 source GigabitEthernet0/1
 transport udp 2055
 template data timeout 60
 option application-table timeout 60
 option application-attributes timeout 300
For NBAR2 the important command is "option application-table" - this will enable the sending of a list of all applications that can be classified using NBAR2 included those manually created. Here with timeout 60 seconds.
Command "option application-attributes" will enable sending the categories for all applications. Here with 300 seconds timeout.
3. Monitor:
 flow monitor SolarwindsNetflow
 cache timeout active 60
This basically interconnects the flow recorder and flow exporter. There can be configured more than one exporter, recorder and monitor in one time.
Then the configuration of course has to be assigned to interface which we want to monitor Netfow from.
4. Interface:
 interface GigabitEtherent 0/0/1
 ip flow monitor SolarwindsNetflow input
 ip flow monitor SolarwindsNetflow output
For diagnostic purposes it is useful to use following commands:
show flow record "recordName"
show flow export "exporterName"
show flow monitor "monitorName"
show flow exporter statistics
show flow interface
The number of application device is able to recognize depends on Protocol Pack that the device has installed. The Protocol Pack is basically list of applications and their definitions and categories that the device is able to recognize. The Protocol Pack is continuously being updated by Cisco. Each new version typically brings couple of new applications that the router is able to recognize/report.
For checking current installed Protocol Pack issue following command:
show ip nbar version
Output:
NBAR software version:  20
NBAR minimum backward compatible version:  20
Loaded Protocol Pack(s):
Name:                            Advanced Protocol Pack
Version:                         14.0
Publisher:                       Cisco Systems Inc.
NBAR Engine Version:             20
Creation Time:                   Wed Mar 25 13:17:24 UTC 2015
File:                            flash0:pp-adv-isrg2-154-3.M2-20-14.0.0.pack
State:                           Active
The currently installed Protocol Pack is in version 14. Protocol Pack can be dependent on IOS version, so it could happen that before installing new Protocol Pack user will have to upgrade his IOS first.
A List of all available applications can be viewed after issuing following command:
show ip nbar protocol-id
Flow with Application ID:
If the application attributes are configured(command "option application-attribute"), device periodically sends list of attributes for all applications in following format:
