Advanced Authentication Options for the SolarWinds Platform
This article provides information about authentication options within the SolarWinds Platform. While Multi-Factor Authentication (MFA) is not supported natively in the SolarWinds Platform, you can use CAC/PKI smart card or SAML authentication.
All currently-supported SolarWinds Platform products support Smart Card (CAC/PKI) user authentication. See Enable Smart Card (CAC/PKI) user authentication for Orion Web Console.
Starting with SolarWinds Platform 2018.4, you can log into the SolarWinds Web Console using the Security Assertion Markup Language (SAML) v2 protocol for supported identity providers, including Active Directory Federation Services (AD FS) and Okta. See Authenticate Orion users with SAML v2.
To learn more about using MFA in the SolarWinds Platform, refer to these resources:
