How to Move a Node to a Different Polling Engine in the SolarWinds Platform Web Console
This article shows you the step by step procedure on how to move the node to different poller.
10/11/2018 7:09 PM
7/21/2023 8:06 AM
Moving nodes to another poller is a process that can be completed by following the steps below.
Orion Platform
  1. Go to Manage Nodes.
  2. Check the node(s), you want to move, click More Actions, and select Change Polling Engine.
  3. Select your polling engine, and then click Change Polling Engine.
