Security Compliance
Mount error 112 when upgrading LEM
The following error is displayed after entering the network share details and credentials while upgrading LEM: Mount error 112.
11/29/2018 10:48 PM
4/25/2019 1:57 PM
Mount error 112
Log & Event Manager
This error may be caused by disabling support for SMBv1(client) in Windows active directory group policies, or directly by MS in your Windows release or the domain admin via GPO due to being outdated - i.e SMBv1 not as secure as compared to its counterparts SMBv2 and SBMv3.
Refer to Stop using SMB1 (© 2017 Microsoft available at https://blogs.technet.microsoft.com/, obtained on June 12, 2017) for an explanation on why SMB1 is disabled in the latest Windows version.
LEM version up to and including 6.3.1 HF6, only supports SMBv1 Client protocol. Support for SMB v2 and V3 is planned in upcoming major releases of LEM.
Perform any of the following options:
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
