Monitoring Multiple Agents With the Same IP Address On A Single Polling Engine
This article discusses monitoring multiple agents with the same IP on a single polling engine.
10/25/2018 1:48 PM
4/29/2020 10:19 AM
This article discusses the possibility of monitoring overlapping or duplicate IP addresses on a Single Polling Engine using either the SolarWinds Windows or Linux Agent. (Systems Only)
Orion Platform
  • The SolarWinds Agents supports overlapping IP addresses without any issues.
  • The only case where this may not work is where the hostname, IP, and SID are all identical as a result of cloning/imaging the endpoint.
  • At the very minimum, the SID must be unique between each endpoint.
For More about monitoring nodes across the WAN or behind a router please see the following Knowledge Base Article:
How to Monitor Nodes in a WAN - Add NATED nodes in Orion
