Applications Systems
Monitor message queues for Exchange 2013 in SAM
This article provides brief information on monitoring the Exchange 2013 queue for both basic and advanced.
This template contains basic performance counters and services for monitoring Exchange 2013 Mailbox Role. This template is designed to work out of the box and does not require any additional configuration. If you need more detailed monitoring you should use it in combination with the Exchange 2013 Mailbox Role Counters (Advanced) template.
For the template's full specification, see Exchange 2013 Mailbox Role Services and Counters.
For more information regarding templates and SAM configuration see the Support Center Training Page which is full of videos and helpful documentation.
