Monitor and unmonitor ports in UDT
This article explains how you can monitor and unmonitor ports in User Device Tracker. This is a useful way to monitor important information in your network.
1. Log in to Orion Web Console with an admin account.
2. Click Settings > All Settings.
3. Click UDT Settings.
4. Click Manage Ports.
5. Ensure the Show dropdown is set to ports and not nodes.
6. Locate the ports you want to unmonitor and check the box then click the unmonitor button.
7. To re-monitor when desired, repeat the process and click monitor instead.
