Applications Systems
Monitor an application process launched from a specific path
This articles provides information on monitoring an application process launched from a specific path.
11/29/2018 10:34 PM
11/25/2022 3:48 PM
This article provides information on monitoring an application process launched from a specific path.
Server Application Monitor
For example:
Imagine your organization uses an application that runs multiple instances of the same executable file for specific data needs. You can filter and select which instances of a process you want to monitor, based on the command line arguments of the process.
For Example:
There are several Svchost.exe and you would like to monitor the process with LocalServiceNoNetwork
You can use the "Command Line" filter to get information about the concrete instance(s). Check the command line using Task Manager (it is hidden by default) and if the command line contains the full path, you can use it as a filter.
Once you know the command line for the process, you can set up a Process Monitor (WMI) and SolarWinds SAM will display each process ID (PID) in the dashboard with the filter.
Take note on the Command Line Filter, where you saw from the Task Manager
-k LocalServiceNoNetwork
After the filter has been applied, the component details will only display the information of the process.
NOTE: Filtering only works for WMI fetching method and not via RPC
