Security Compliance
Monitor vCenter logs in SEM
This article provides information on how to configure SEM connector to monitor vCenter logs.
- Log in to the SEM Events Console (available from 6.4 and higher) via https://yourlem/webui.
- Click on Nodes -> Manager Connectors.
- Search for vCenter as shown.
- Select the connector, and then click Add Connector.
- Change the log file path if different, or leave the default, and then click Add.
- Under Configured connectors, select the connector, and then click Start.
