Monitor SNMP Nodes Without ICMP Connectivity in NPM
This article describes how to monitor SNMP nodes that do not have ICMP connectivity.
10/19/2018 6:20 PM
9/21/2021 2:42 PM
There are scenarios where ICMP is disabled for nodes due to security protocols on the customer's network. This article provides steps on how to monitor SNMP nodes that do not have ICMP connectivity.
Network Performance Monitor
Orion generally uses ICMP to determine node status and SNMP to collect statistical information. When you add a node that has SNMP connectivity and ICMP traffic is blocked or disabled, you may encounter an error when adding the node as "SNMP and ICMP."
  1. Add the device as an "External Node: No Status" device.
  2. Browse to the newly added node in the web console and click on "Edit Node."
  3. Set the polling method to "Most Devices: SNMP and ICMP." When you save this, you may be presented with a warning, which can be accepted.
  4. Browse to node in the web console and click  "List Resources."
  5. Change the "Status & Response Time" to SNMP. This will have Orion poll the device's status via SNMP.
These steps will let you add a node without ICMP connectivity and alter polling to be purely SNMP based polling.
