Monitor Juniper firewall cluster
How to monitor a failover cluster of Juniper firewalls.
Some users may want to monitor a failover cluster of Juniper firewalls. Since this is not presently supported in the SolarWinds Platform, it may be best to monitor active, passive, and VIP addresses.
- The cluster is accessed via a V.I.P. (Virtual IP address) and the active and passive physical IP addresses.
- The passive IP is not accessible until the system fails over.
- In order to monitor the cluster, it is best to monitor the VIP and the active and passive IPs.
