Monitor Juniper Firewall hardware status
This article provides steps on how to create and use a Universal Device poller (UNDP) to monitor Juniper Netscreen-ISG 2000 Firewalls. This focuses on the Juniper NetScreen-ISG 2000 code version 6.3.0r21.0. The firewall provides the following OIDs (which can be verified using a SNMP walk) to allow monitoring of FAN, Power and temperature.
1.3.6.1.4.1.3224.21.1.1.3.1 Primary Power
1.3.6.1.4.1.3224.21.1.1.3.2 Secondary Power
1.3.6.1.4.1.3224.21.2.1.3.1 Fan 1
1.3.6.1.4.1.3224.21.4.1.4.1 CPU/Management Board Temperature
1.3.6.1.4.1.3224.21.4.1.4.2 System Board Temperature 1
1.3.6.1.4.1.3224.21.4.1.4.3 System Board Temperature 2
- Open SolarWinds Orion Menu and Start the Universal Device Poller.
- Select New Universal Device Poller.
- Using the OIDs listed in the overview section of this article, fill in the OID field.
- Show Advanced Options in order to choose the data formatting.
- Select Keep Historical Data if you need to store the data for that device.
- Enable the poller if you want to start polling immediately
- Choose a group for your UnDP.
- In the next page, assign your UnDP to the nodes that need to be polled.
- Test that all the nodes can be polled.
- Choose how to display the UnDP and on what pages you want it displayed on the Web Console.
