Applications Systems
Monitor JBoss EAP in domain mode with JMX and SNMP
This article describe the steps on how to configure JBoss JMX and SNMP in domain mode.
11/29/2018 10:34 PM
11/29/2018 10:34 PM
Server Application Monitor
1. Configuring JBoss JMX in Domain Mode
https://developer.jboss.org/wiki/Usi...nectToJMXOnAS7
Note:
Domain mode where {port} is the JMX subsystem interface of the AS7 installation being monitored (first server=4447, port-offset=150 next server).
Manual changes in Jboss-7.1.0.Final in domain.xml -thanks to https://community.jboss.org/thread/196236
<subsystem xmlns="urn:jboss:domain:jmx:1.1">
   <show-model value="true"/>
   <remoting-connector use-management-endpoint="false"/>
</subsystem>
B. Configuring JBoss SNMP in Domain Mode
https://developer.jboss.org/wiki/JVM...nagiosTemplate
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
