Monitor Disk IOPS in Orion
Disk IOPS are only currently available when the node is monitored via WMI.
10/25/2018 7:51 PM
9/18/2023 11:41 PM
This article explains how Orion monitor Disk IOPS.
Network Performance Monitor
Disk IOPS are only currently available when the node is monitored via WMI polling.
  1. Add the node using the WMI polling method in the Orion Web Console.
    (Home Summary tab > All Nodes Resources > Click Manage node box > Click Add node)
  2. To see the Disk IOPS resource, just add it within Node Details Page.
    (Open Orion web console > Drill Down to Node details page)
  3. Click Customize page > type IOPS in search box >  Select the desired IOPS resource you need (Ex. Top 10 Total IOPS). See screenshot below for an example:
