Modify a default device template in NCM
This article describes how you can modify a device template in NCM
- Open the SolarWinds Platform Web Console.
- Go to Settings > NCM Settings.
- In the Advanced section, click Device Templates.
- To help narrow the list of Templates, type a keyword and click the Magnifying glass to query.
- Put a check next to the template you want to modify, and click edit, then select edit using XML Editor.
- Since this is a default template, you need to duplicate and Edit.
- Input a name for the new template.
- If the template is intended to be used on a specific device, use sysObjectID from this device (value can be found in Node Details resource on Orion Web Console).
- Edit the device template and save.
- If you matched the sysObjectID to the device this is for or intend to replace the default template, set the flag to yes for Use for auto-detect. If you duplicated an OID or Device template name, and you have set this to Use for auto detect, disable the default template to be used for auto-detect.
