Modify Database Maintenance schedule for Orion Platform products
By default, the Database Maintenance runs at 2:15 a.m. You can change the time for running Database Maintenance in Orion Platform products in the Settings.
10/25/2018 7:36 PM
9/13/2022 9:52 AM
This article provides the steps to modify the Database Maintenance Schedule.
Network Performance Monitor
Note: Database Maintenance runs automatically daily by default at 2:15 am.
  1. Log in to your Orion Web Console.
  2. Click on Settings.
  3. Under Thresholds & Polling, click on Polling Settings.
  4. Scroll down and look for Database Settings.
  5. In Archive Time, change the default information to your target time.
  6. Click Submit to save changes.
