Mismatched SWA Versions betwwen Orion servers
SolarWinds Administration Service versions are mismatched across polling engines. Wrong versions of the SWA service.
Check the SolarWinds Administration Service on each polling engine. If you're proficient with SQL, the OrionServers table contains the SWA version of every engine. You can also check manually through Programs & Features in the Control Panel of every polling engine.
- Find the correct SWA version installed on the main engine.
- Copy the MSI file from the installers directory to the additional polling engine installers directory that has the incorrect version. The installer will look similar to "SWA-X.X.X.xxxx-AdministrationService.msi"
- C:\ProgramData\SolarWinds\Installers\
- Run the MSI.
Note: X.X.X.xxxx is the numerical version of SWA
If the correct version of msi is missing from the installer directory, then contact SolarWinds support.
