Applications Systems
Miscellaneous SAM script components
This article lists the miscellaneous SAM script components.
11/9/2018 7:54 PM
9/7/2022 8:42 PM
This article lists the miscellaneous SAM script components. See Use script monitors in SAM for reference.
Server Application Monitor
  • ${IP}
  • ${USER}
  • ${PASSWORD}
  • ${creds}
  • ${PORT}
  • ${Node.SysName}
  • ${Node.Caption}
  • ${Node.DNS}
  • ${Node.ID}
  • ${Component.ID}
  • ${Component.Name}
  • ${Application.Id}
  • ${Application.Name}
  • ${Application.TemplateId
  • ${Threshold.Warning}
  • ${Threshold.Critical}
  • ${Node.Custom.CustomPropertyName}
  • ${Application.Custom.CustomPropertyName}
Add the following macros as the script argument and use the argument in the script body.
Script arguments:    ${Node.Caption}
Script Body:             $ServerName =  $args[0]
See also:
SAM PowerShell Monitors are not working
