Applications Systems
Miscellaneous SAM script components
This article lists the miscellaneous SAM script components.
This article lists the miscellaneous SAM script components. See Use script monitors in SAM for reference.
${IP}${USER}${PASSWORD}${creds}${PORT}${Node.SysName}${Node.Caption}${Node.DNS}${Node.ID}${Component.ID}${Component.Name}${Application.Id}${Application.Name}${Application.TemplateId${Threshold.Warning}${Threshold.Critical}${Node.Custom.CustomPropertyName}${Application.Custom.CustomPropertyName}
Add the following macros as the script argument and use the argument in the script body.
Script arguments: ${Node.Caption}
Script Body: $ServerName = $args[0]
See also:
SAM PowerShell Monitors are not working
