OIDs required to add a device as an SNMP node
This article provides the minimum OIDs required to add a device to the SolarWinds Platform using SNMP.
11/13/2018 4:14 PM
2/26/2025 9:45 PM
Review the OIDs that need to be present on a device so that you can monitor the device with the SolarWinds Platform. Without these OIDs, the SolarWinds Platform will not recognize the device.
Orion Platform
These are the minimum OIDs required to add a device to the SolarWinds Platform.
  • 1.3.6.1.2.1.1.1.0 sysdescr
  • 1.3.6.1.2.1.1.2.0 sysobjectid
  • 1.3.6.1.2.1.1.3.0 sysuptime
