Min/Max/Avg graph of round trip time not appearing in IPSLA operation detail page
This article explains how to ensure that the resource views in IPSLA VNQM is in default settings.
- Log in to Orion Console and then go to All settings.
- Click Manage accounts.
- Select the account being used and click edit.
- Scroll down at the bottom of the screen.
- Expand VOIP AND NETWORK QUALITY MANAGER SETTINGS.
- Make sure that IP SLA Operation Details view is on Default.
- Click Submit.
- Check if you will see RTT resource for ICMP based IPSLA operations.
