Database Management
Migration paths for SolarWinds SQL Sentry
This article describes supported migration paths for SolarWinds SQL Sentry, including database and component migrations for both Unified Installer and Enhanced Platform Installer (EPI) deployments. Use this guide when you need to: Move the SQL Sentry database to a new SQL Server. Move Monitoring Services, Controllers, Portal, and/or Clients to new machines. Perform both a database and component migration, with minimal disruption.
Preparation
Complete these preparation steps before starting any migration path.
Decide on upgrade vs. migration order
If you plan to upgrade SQL Sentry, perform the upgrade before migrating.
Keeping upgrade and migration separate reduces complexity and makes troubleshooting easier.
Obtain the correct installers
If you are not upgrading, download and keep the installer that matches your current SQL Sentry version.
Use this same installer when installing SQL Sentry components in the new location.
Validate system and security requirements in the new environment
System requirements for each new server
Monitoring Service security requirements are met, so services can connect to all monitored targets.
Required ports are open.
Follow SQL Sentry installation recommendations for sizing and placement.
Capture current Portal configuration
Review and document your Portal configuration in the existing environment.
You will need this information to reconfigure Portal after it is migrated.
Migration paths overview
Use the table below to select the path appropriate for your deployment type and what you are moving.
Path |
Deployment type |
What are you moving |
Section |
1 |
Unified |
SQL Sentry database only |
Path 1 |
2 |
Unified |
SQL Sentry components (Client/Monitoring/Portal) |
Path 2 |
3 |
EPI |
Path 3 |
4 |
EPI |
SQL Sentry components (Controller/Monitoring/Portal/Client) |
Path 4 |
Path 1: Unified SQL Sentry database migration
Use this path when you have a Unified SQL Sentry deployment and are moving the SQL Sentry database to a new SQL Server, while keeping services and clients (initially) on their existing servers.
Steps
Stop services
On all SQL Sentry servers, stop:
Monitoring Services
Portal Service
Deactivate licenses
Open the SQL Sentry Client.
Go to Help > Manage Licenses and deactivate your licenses.
Ensure no services are started after this point until the migration is complete, as doing so can cause targets to be unwatched.
Close the SQL Sentry Client after deactivating licenses.
Back up the SQL Sentry database
Perform a full backup of the existing SQL Sentry database on the current SQL Server.
Restore the database to the new SQL Server
Restore the backup to the new SQL Server that will host the SQL Sentry database.
Update client connections
On any machine where the Client is not being migrated:
If the old database is still accessible, the Client will connect using the existing default connection.
Go to File > Connect to installation and:
Edit the existing connection to point to the new SQL Sentry database server, or
Add a new connection pointing to the new database location.
Repeat this for all Client machines that are staying in place.
Update Monitoring Service connections
On any machine where the Monitoring Service is not being migrated:
Run the Service Configuration Utility.
Input the Monitoring Service username and password.
Update the SQL Sentry database connection if needed.
Once completed, press any key to close out of the dialog.
Reactivate licenses
Using the updated connection that points to the new SQL Sentry database, open the Client and reactivate your licenses.
Start services
Path 2: Unified SQL Sentry component migration
Use this path when you have a Unified SQL Sentry deployment and are moving Clients, Monitoring Services, and/or Portal Services to new machines. This is typically done after moving the database (Path 1), but can be used on its own if the database host is not changing.
Steps
Uninstall SQL Sentry from old component servers
On every machine that currently hosts any of the following:
SQL Sentry Client
SQL Sentry Monitoring Service
SQL Sentry Portal Service
Go to Add or Remove Programs (or Apps & Features) and uninstall SQL Sentry.
Install components on new servers
On each new machine where you are moving a Client, Monitoring Service, and/or Portal Service:
Run the Unified Installer obtained during the preparation stage.
Walk through the installation wizard.
When prompted for what to install, choose the appropriate option:
Complete – installs Client, Monitoring Service, and Portal Service.
Client Only – installs only the Client.
Custom – allows you to select specific components (for example, only Portal).
Verify Client connectivity
After installation completes, if a Client was installed:
Open the Client.
Confirm that it connects to the SQL Sentry database specified during installation (typically the migrated database from Path 1).
Path 3: EPI SQL Sentry database migration
Use this path when you have an Enhanced Platform Installer (EPI) deployment and you are moving the SQL Sentry database to a new SQL Server, while initially leaving Controllers, Monitoring Services, Portal, and Clients on their existing servers.
Steps
Stop services
On all SQL Sentry EPI servers, stop:
Controller Services
Monitoring Services
Portal Service
Deactivate licenses
Ensure no services are started after this point until the migration is complete, or most monitored targets may be unwatched.
Perform a full backup of the existing SQL Sentry database.
Restore the backup to the new SQL Server designated to host the SQL Sentry database.
Update registrations for Clients not being migrated
For any machine where the Client is not being migrated, use the EPI command-line tools to point that Client to the new SQL Sentry database:
Open Command Prompt as an administrator.
Run
so addregto create a new registration that points to the new database:so addreg -n <connectionName> --connectionServer <serverName> --connectionDatabase <databaseName>-
<connectionName>– A friendly name for this registration (you will reuse this-nvalue in other commands). -
<serverName>– New SQL Server name. -
<databaseName>– SQL Sentry database name.
Repeat this process on any Client machines that are staying in place.
Update registrations for Monitoring Services not being migrated
Run
so updateregto edit the registration the Monitoring Service uses to connect to the database:so updatereg -n <connectionName> --connectionServer <newConnectionServerName> --connectionDatabase <databaseName>-
<connectionName> – The name of your existing connection you will be using (you will reuse this -n value in other commands).
<newConnectionServerName> – New SQL Server name.
<databaseName> – SQL Sentry database name.
Reactivate licenses
With the new registration in place:
Start the Client, select the new connection, and reactivate your licenses.
Start services
Path 4: EPI SQL Sentry component migration
Use this path when you have an EPI deployment and are moving Controllers, Monitoring Services, Portal, and/or Clients to new machines. This is typically done after moving the database (Path 3), but can also be used independently if only application components are moving.
Steps
4.1 Uninstall services and application components from old servers
Uninstall EPI services (Controller/Monitoring/Portal)
On every machine that currently hosts a Controller, Monitoring Service, and/or Portal Service:
Run the
so uninstallcommand to remove all EPI services associated with the registration:so uninstall -n <connectionName>
Uninstall the SQL Sentry/SentryOne application
On the same machines:
Go to Add or Remove Programs (or Apps & Features).
Uninstall SolarWinds SQL Sentry/SentryOne.
Uninstall Clients that will move to new machines
On any machine that currently has a Client that will be relocated:
Go to Add or Remove Programs.
4.2 Install EPI framework and register against the new database
Install EPI framework on new service servers
On every new machine where you are moving a Controller, Monitoring Service, and/or Portal Service:
Run the Enhanced Platform Installer (EPI) file obtained during preparation.
Walk through the installation wizard to install the EPI Framework.
Add a new registration to the new SQL Sentry database
After the EPI framework is installed, on each new service server:
Run
so addregto register the framework to the new SQL Sentry database:so addreg -n <connectionName> --connectionServer <serverName> --connectionDatabase <databaseName>-
Use the same
<connectionName>value consistently; it will be referenced in other commands.
4.3 Reinstall services
Install Controller and Monitoring Services
With the registration in place, reinstall EPI services using
so install:so install --IAcceptLicenseTerms -n <connectionName> -u <serviceAccount>-
<serviceAccount>– The service account that will run the SQL Sentry services.
Install Portal Service (if applicable)
If the Portal will also run on this server, install the Portal service using
so installmp:so installmp --IAcceptLicenseTerms -n <connectionName> -s <PortalServiceServerFQDN> -u <serviceAccount>-
<PortalServiceServerFQDN>– Fully qualified domain name of the Portal server. -
<serviceAccount>– Service account for the Portal service.
Reconfigure Portal
After Portal is installed:
so configmp -
Use the configuration UI to:
Confirm connection details.
Reapply any Portal configuration captured during the Preparation phase.
4.4 Finalize and validate
Start a Client and verify connectivity
Each EPI framework installation also adds a Client shortcut, so you can open a Client from any service machine.
Connect to the new SQL Sentry database and confirm:
Controllers and Monitoring Services are visible.
Portal status is healthy.
Organize Monitoring Services into Sites
In the Client:
Navigate to Monitoring Services.
Move each Monitoring Service into the appropriate Site (drag-and-drop).
Remove any old Monitoring Services that refer to servers that are no longer in use (they will still appear in the Monitoring Services folder until removed).
Reactivate licenses (if not already completed)
Ensure licenses are active for the installation connected to the new database.
Post-migration checks
After completing the appropriate path:
Confirm all monitored targets are still watched and collecting data.
Review alerts and actions to ensure they are firing as expected.
Verify Portal access:
Users can log in.
Dashboards, performance data, and event views load correctly.
Validate maintenance tasks (such as grooming/cleanup) are running against the new database.
