Migrate existing NCM rules to web-based LA rules
This article explains how to manually migrate existing NCM rules to the new web-based Log Analyzer (LA), formerly Log Manager for Orion, rules.
10/18/2018 2:30 PM
10/18/2018 2:30 PM
You can apply existing NCM Real-Time Change Notification (RTCN) rules to your current LA log-processing rule set. When LA detects NCM RTCN rules, you will receive a notification in the Orion Web Console.
For more information, see Configure Real-time Configuration Change Detection Based on Syslog Messages.
Log Analyzer
  1. On the Log Viewer toolbar, click Configure Rules.
  2. In the Processing Policies pane, click to expand Syslog or Traps, and then click NCM Rule: Real-Time Change Notifications. Each rule displays the established condition and subsequent action.
  3. To enable a rule, select a rule check box, and then click Enable Rule.
  4. To return to the Log Viewer, navigate to My Dashboards > Logs > Log Viewer.
