Merge standalone IPAM installation into an existing NPM installation
Can you merge a standalone IPAM installation with an existing NPM installation?
11/6/2018 5:36 PM
1/3/2025 7:05 PM
This article discusses best practices for merging a standalone IPAM installation into an existing NPM installation.
IP Address Manager
SolarWinds strongly advises customers NOT to attempt to merge a standalone IPAM installation into an existing NPM installation. The SolarWinds Platform does not support the merging of databases. There are many constraints and dependencies which would make a successful merge impossible.
