Manually running Scheduled Reports: Failed due to incorrect MTP Server in the Orion platform
This article provides brief information and steps to resolve the following error when Scheduled Reports in Orion fail: SCHEDULE(S) EXECUTION RESULT <Report Name> Failed
10/25/2018 6:53 PM
2/17/2022 12:25 AM
This article provides step by step process on how to resolve a Failed error when manually running a scheduled report.
Network Performance Monitor
The error is caused when SMTP Server in Orion does not have proper authentication credentials.
  1. Go to C:\ProgramData\Solarwinds\Logs\Orion and locate ActionsExecutionReport.log.
  2. Open the file using a text editor.
    You should have something similar to this:
  1. Open Orion Console > Settings > Manage SMTP Servers.
  2. Select This SMTP server requires authentication.
  3. Edit it, and provide the correct credentials. See below:
  1. Click Save.
