Manually running Scheduled Reports: Failed due to incorrect MTP Server in the Orion platform
This article provides brief information and steps to resolve the following error when Scheduled Reports in Orion fail: SCHEDULE(S) EXECUTION RESULT <Report Name> Failed
This article provides step by step process on how to resolve a Failed error when manually running a scheduled report.
- Go to C:\ProgramData\Solarwinds\Logs\Orion and locate ActionsExecutionReport.log.
- Open the file using a text editor.
You should have something similar to this:
- Open Orion Console > Settings > Manage SMTP Servers.
- Select This SMTP server requires authentication.
- Edit it, and provide the correct credentials. See below:
- Click Save.
