Tools
Manually activate license keys for Kiwi products
Manual license activation is necessary if your server does not have internet access or is having activation issues due to a proxy server.
- Open the Service Manager > Help > Enter License Details.
- Click Enter Licensing Information. The activation wizard opens.
- Select This server does not have internet access. Guide me through offline, manual activation, and click Next.
- Click Copy Unique Machine ID.
- Paste the Unique Machine ID into a text editor document. You will use this ID in the next step.
- On a computer with internet access:
- Login to the SolarWinds Customer Portal.
- Browse to Licenses > Manage Licenses.
- Locate the Kiwi product you are activating.
- Click Activate license manually.
- Enter the required contact information. The activation key is entered for you and cannot be changed.
- Enter the Unique Machine ID copied from Step 3.
- Click Generate License File to download your license key (.lic) file.
- Save this file to a location on your product's server.
- Reopen the activation window and click Browse next to the License Key File location field.
- Navigate to the saved license file, and click Open.
- Click Next to apply the key.
- Once the activation has been confirmed, click Finish.
- Click Restart Syslog Server.
