Manage Nodes and Network Discovery are missing in the Settings drop-down menu
This article addresses an issue in the Orion Web Console that prevents the Manage Nodes and Network Discovery options from displaying in the Settings drop-down menu.
- Open the Orion Database Manager and locate the following tables.
- Engines
- Website
- OrionServer
- Check to see if Old Orion Server is listed in the table.
If Old Orion Server is listed, delete the entry from the tables. - Deactivate the license.
- Run the License Manager.
