Monitoring CRC (cyclic redundancy check) errors of network devices using Orion NPM
This article gives you some recommendations about monitoring CRC (cyclic redundancy check) errors of network devices using Orion NPM.
Create UnDP with CRC monitor with OID 1.3.6.1.4.1.9.2.2.1.1.12.
Referring to thwack article: https://thwack.solarwinds.com/thread/71338
You might need to consider monitoring CRC error as it does not reset without rebooting the device itself:
Please note that Thwack is a community space where users may post any content as a suggestion or recommendations to you for your internal use. The information set forth herein may come from third-party websites or customers. SolarWinds is not liable for any downtime or any issue that may occur if you perform the following suggestions on the link provided. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.
