Tools
MLST FTP command
The MLST command is defined in the IETF working draft Extensions to FTP. It is sent from the client to the server in order to retrieve information about a specific entity. Unlike similar commands used to retrieve information, the response is sent over the command channel. Therefore, no data connection is required to issue this command. The MLST command may be issued with an optional parameter that specifies the entity the server should return information about.
This article describes the use of the Machine List (MLST) FTP command.
The MLST command is defined in the IETF working draft Extensions to FTP (© 2018 IETF Tools available at https://tools.ietf.org/, obtained on 2018). It is sent from the client to the server in order to retrieve information about a specific entity. Unlike similar commands used to retrieve information, the response is sent over the command channel. Therefore, no data connection is required to issue this command. The MLST command may be issued with an optional parameter that specifies the entity the server should return information about. If no parameter is provided, then the server must return information about the user's current directory.
Common responses
- 250 FTP response code
- 421 FTP response code , 450 FTP response code , 451 FTP response code
- 500 FTP response code , 501 FTP response code , 502 FTP response code , 530 FTP response code , 534 FTP response code , 535 FTP response code
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
