Tools
Look and Feel page never loads after upgrade to WHD 12.8.4 and 12.8.5
After upgrading to WHD 12.8.4 or 12.8.5, the Look & Feel page never loads
If you go to to Setup > General > and click on Look & Feel, it shows that it is loading but it never does. This eventually causes the application to freeze and only a restart will get it going again.
- Missing File in WHD 12.8.4
- Bug File in WHD 12.8.5
This issue is fixed in WHD 12.8.6 and above. Consider upgrading your environment. If you can't upgrade, use the workaround below.
Workaround:
Replacing the missing file
1. Obtain the missing file from a WHD 12.8.3 installation.
- Navigate to <Web Help Desk home directory>\bin\webapps\helpdesk\WEB-INF\lib\
- Copy the jabsorb.jar file
2. On WHD 12.8.4/12.8.5, replace/paste the file to the same path above.
3. Restart the WHD server.
