Security Compliance
Log retention limit is unchanged after running dbdiskconfig in the CMC shell in SEM
What to do if, after running the dbdiskconfig command to change the percentage limit for your database, the SEM still seems to be dropping events at the previous value.
11/8/2018 7:09 PM
11/8/2018 7:09 PM
After you run the dbdiskconfig command to change the percentage limit for your database, the Security Event Manager (formerly Log & Event Manager) continues to drop events at the previous value.
The dbdiskconfig script does not update the necessary values.
Contact SolarWinds Support  to make the necessary changes.
