Tools
Load Kiwi Syslog Daemon default settings
Kiwi Syslog Daemon sometimes gets an error of being unable to receive messages and using the default rules and settings triggers the action to fix the problem.
10/18/2018 5:16 PM
10/18/2018 5:16 PM
Kiwi Syslog Daemon sometimes displays an error that it is unable to receive messages. Reloading the default rules and settings triggers the action to fix the problem.
Kiwi Syslog Server
​​​​To load the default rules and settings:
  1. Go to File Setup Defaults/Import/Export.
    Five options appear on the right side of Kiwi Syslog Server.
  2. Choose Load default Rules and Settings.
    A verification prompt asks if you want to use the default rules and settings.
  3. Click Yes.
