Applications Systems
List Resources will not submit
List resources page will not submit change. List Resources not working. Stuck on list resources. Page not loading. List resources is hung, timed out or times out. Restart services, restarting Orion services.
Preliminary investigation will include reproducing the issue by clicking the SUBMIT button and visiting the website server at the log location:
%ProgramData%\SolarWinds\Logs\Orion\OrionWeb.log
The log should share information on the issue. Possibly an issue with an unresponsive business layer such as:
ERROR ASP.global_asax - (null) Application_Error(a05c8d1b523c4af5935a3b0ac3e812a6)
SolarWinds.ApiProxyFactory.TransientApiProxyException: Exception of type 'SolarWinds.ApiProxyFactory.TransientApiProxyException' was thrown. ---> System.ServiceModel.EndpointNotFoundException: There was no endpoint listening at net.tcp://<servername>:17777/orion/apm/businesslayer that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details.
Server stack trace:
at System.ServiceModel.Channels.ConnectionUpgradeHelper.DecodeFramingFault(ClientFramingDecoder decoder, IConnection connection, Uri via, String contentType, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.SendPreamble(IConnection connection, ArraySegment`1 preamble, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.DuplexConnectionPoolHelper.AcceptPooledConnection(IConnection connection, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
- Unresponsive business layer
- Other/Unknown
Start, stop, or restart Orion services with the Orion Service Manager
In some cases, the business layer may not be functioning correctly. In these cases, it is best to contact SolarWinds support for further investigation on the misbehaving business layer and how to remediate it.
