Applications Systems
Linux monitoring File Systems / Mounts for Read-Only changes
This article provides brief Information on monitoring changes on Linux servers, other than network availability via SNMP/ICMP.
11/29/2018 10:34 PM
5/7/2026 3:14 PM
See Linux read-only file  for more information.
Server Application Monitor
1. Go to the Settings option in the top right of your SAM Web Console.
2. Under Product specific settings, select SAM settings.
3. Select Manage Application Monitors.
4. From Manage Assigned Application Monitors.
5. Select Shared Templates on Thwack.
6. Import Linux read-only file.
Once imported, you should be able to apply the template to the target node.
