Tools
Linux Agent for Dameware Remote Everywhere
Learn about the Linux Agent for Dameware Remote Everywhere
- Does Dameware Remote Everywhere support a Linux Agent install?
- How to generate a .deb or .rpm Agent installer?
- Login to your Console.
- Select the My Computers tab.
- Click on the ADD COMPUTER button.
- Fill out the form as intended.
- Set Device Type to either:
- Linux .deb (Debian, Ubuntu).
- Linux .rpm (OpenSUSE, CentOS, Red Hat).
- Press GENERATE LINK - this will generate the download link and PIN Code for the .deb or .rpm file.
- Please note that these Agents are currently still in development and may not yet have, but are intended to, in future iterations, reach, feature parity with our Windows and macOS/OSX Agents.
