Links Aggregation do not show utilization
This article provides brief information and steps to resolve the issue when Links Aggregation do not allow show utilization.
This article provides brief information and steps to resolve the issue when Links Aggregation do not allow show utilization. Device: Alcatel
1. Run UNDP 1.3.6.1.2.1.2.2.1.2.
2. IfIndex(1)
3. Copy the Row ID.
4. Select ifDescr(2).
5. Look for same Row ID and see if the value is 0 -
Note: If 0, then it is not supported.
You need to get an OID from the vendor to create a UNDP (Universal Device Poller).
See What object IDs (OIDs) does NPM poll for interface information
