Legacy NetFlowTrafficSummary/NetFlowTopXXSummary Resources Missing in NTA Web Console
NetFlow Traffic Analyzer Summary page show red errors for multiple legacy widgets: Search by Endpoint Search by Application/Port Traffic View Builder Top XX Applications Top XX Endpoints Top Conversations
3/23/2026 8:11 PM
8/5/2026 12:32 AM
Example errors:
  • The "Search by Endpoint " resource is missing. The file \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\SearchEndpoints.ascx is not found.
  • The "Search by Application/Port " resource is missing. The file \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\SearchApplications.ascx is not found.
  • The "Traffic View Builder " resource is missing. The file \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\NetFlowCustomFilter.ascx is not found.
  • The "Top XX Applications " resource is missing. The file \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\TopApps.ascx is not found.
  • The "Top XX Endpoints " resource is missing. The file \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\TopXXEndpoints.ascx is not found.
  • The "Top Conversations " resource is missing. The file \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\TopConversations.ascx is not found.
NTA collection and other modern NTA resources continue to work. The impact is limited to these legacy UI widgets.
Affected Components
  • NetFlow Traffic Analyzer (NTA):
    • Deployed and licensed
    • NTA flows confirmed on APE / collector
  • Primary web server / MPE:
    • Hosts SolarWinds web console
    • NTA installed/selected in the Platform Installer
Symptoms
On NTA Summary:
  • Red error blocks instead of NTA widgets:
    • Search by Endpoint
    • Search by Application/Port
    • Traffic View Builder
    • Top XX Applications
    • Top XX Endpoints
    • Top Conversations
  • Error text explicitly references missing .ascx under:
    • \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\
    • \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\
Netflow Traffic Analyzer
Root Cause
  • The following legacy UI resources are effectively retired and are no longer deployed on clean/updated installs:
    • \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\SearchEndpoints.ascx
    • \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\SearchApplications.ascx
    • \Orion\TrafficAnalysis\Resources\NetFlowTrafficSummary\NetFlowCustomFilter.ascx
    • \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\TopApps.ascx
    • \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\TopXXEndpoints.ascx
    • \Orion\TrafficAnalysis\Resources\NetFlowTopXXSummary\TopConversations.ascx
  • The default NTA Summary view definition still references those resources.
  • As a result, after upgrade:
    • The .ascx files are not present on the web server.
    • The Summary view continues to try to render those resources.
    • The web console shows “resource is missing / .ascx is not found” instead of silently hiding them.
Prerequisites and Warnings
  • You must have SQL access to the SolarWinds Platform database.
  • Ensure there is a recent full backup of the SolarWinds Platform database.
  • Changes below affect only the [dbo].[Resources] table:
    • No schema changes
    • Fully reversible via the backup copy
Step 1 – Identify the legacy NTA resources
Run:
SELECT ResourceID, ResourceName, ResourceFile
FROM [dbo].[Resources]
WHERE ResourceFile LIKE '%NetFlowTrafficSummary%SearchEndpoints%'
   OR ResourceFile LIKE '%NetFlowTrafficSummary%SearchApplications%'
   OR ResourceFile LIKE '%NetFlowTrafficSummary%NetFlowCustomFilter%'
   OR ResourceFile LIKE '%NetFlowTopXXSummary%TopApps%'
   OR ResourceFile LIKE '%NetFlowTopXXSummary%TopXXEndpoints%'
   OR ResourceFile LIKE '%NetFlowTopXXSummary%TopConversations%';
You should see rows whose ResourceFile ends with the six legacy paths:
Verify that:
  • No other, unrelated resources are matched.
  • Resource names correspond to the legacy widgets (Search by Endpoint, Search by Application/Port, Traffic View Builder, Top XX Applications, Top XX Endpoints, Top Conversations).
Step 2 – Remove the legacy resources
Once confirmed, run:
DELETE FROM [dbo].[Resources]
Notes:
  • This only removes the resource definitions from the global Resources catalog.
  • Any views that reference them will no longer be able to render them.
  • No changes are made to other NTA resources or to NTA data.
Step 3 – Verify in the Web Console
  1. Log in to the SolarWinds web console.
  2. Navigate to NetFlow Traffic Analyzer Summary.
  3. Confirm:
    • The red error blocks for:
      • Top XX Endpoints
      • Top Conversations
        are no longer present.
    • Other NTA widgets and data still load successfully.
